cass92lx50
- Nov 22, 2007
- yadkinville,nc
That’s what a Ford can do!!
True. They used a 150k junkyard 5.3 with a couple of turbos they found on eBay. Put some polished aluminum valve covers on it, too. Real nice build, that one.I heard they had to LS swap it just to break 200mph
Really?Was unaware the LS was a pushrod motor
Yeah, and a 2.7L turbo would also be plenty sufficient. But this isThis is about the new Bronco. It doesn't need 9k rpm eargasms. It needs cheap, reliable, easy to work on power.
A pushrod motor would be plenty sufficient.
Sent from my Moto G (4) using Tapatalk
Nah, just like tweaking the Ford guys.Dude, you apparently just have a Ford axe to grind.
You are just throwing out shit that ain't true left and right.
A 2.7 with no boost isn't going to have much power in a truck. A quick search found that even the 2 door with the 2.3 weighs 4300 to up around 5000lbs. That's no bueno if you like your truck to get out of its own way. Need that boost to make enough power.How about no turbo?
So much less complexity, less packaging struggle, less heat, less programming, cheaper, and more reliable.
We are talking trucks here, with relatively small payload and towing capacities.
My jeep ran it on tons and 36 swampers at 5200lbs. 16.7sec at 76mph. Just letting you know that we are out here1/4 with your 5k lb SUV
Except for you guys apparently planning to race them through the NC deserts or hit the 1/4 with your 5k lb SUV.
thats not good news...
I just can't bring myself to click the Like button.
A like isn't "agreeing" with the implementation. It's accepting that some douche-canoe outfit dying to make a name for themselves will inevitably execute a very similar design, and Motor Trend TV will send Chris Jacobs out there with some THOT to virtually hand-job the builders while Jesse James calls it a piece of shit and dumps a pile of manure in the driveway of the shop while they're all at SEMAI just can't bring myself to click the Like button.
Good morning Mr Fun Sucker. It was a joke.A like isn't "agreeing" with the implementation. It's accepting that some douche-canoe outfit dying to make a name for themselves will inevitably execute a very similar design, and Motor Trend TV will send Chris Jacobs out there with some THOT to virtually hand-job the builders while Jesse James calls it a piece of shit and dumps a pile of manure in the driveway of the shop while they're all at SEMA
