Mounted up the new-to-me TR beadlocks and got them on the runner
Dang...even the garage floor is pimp:huggy:
This is some shiote the PO had put down. I actually hate it. Any bit of chemicals on it and it just takes it right up and makes a sticky f'n mess!
This shit ain't nothing nearly as baller as some of the concrete finish I've seen on the other side of the tracks (i.e., 109) :flipoff2:
New plugs, wires, cap, rotor, fresh oil/filter, wipers, and fixed the nascar loud exhaust on the S10. Problem now is it’s so quiet I can’t tell when to shift gears lol. I still can’t thank @Lizooki enough. This little truck is a champ! Been driving it to work all last week and it used about a 1/4 tank of gas! I love it!!
Put it on the “For Sale” page.
cleaned up some “welds” on the DIY winch bumper I’m putting on it.
Are you planning on getting something in its place?
Cutting on a truck has never bothered me before,
But cutting the rear of the frame off made me think...
I cut the front crossmember off of my XJ. It popped when it let go and spread like an inch. Gana have to ratchet strap and jack it back into place when I put the bumper back on!
From my experience with wheeled unibody jeeps, if the unibody is only off an inch or so that's a win!!
Sunday I put a new fuel filter on the K 1500. I had only a 12/10 mm flair wrench so I got a set from northern tool.It took about 5 mins. to switch them out w these wrenches and I'm sure I will use them alot for all my wrenching w the different sizes on each end . The quality was better than the harbour freight set and NT was $2 less than the HF set
ATTACH=full]310980[/ATTACH]
First time with me buying smaller tires. It feels weird. Decided I'm dropping down to 33's since i want to keep the jeep uncut. Brown truck showed up today with some 33x10.50r15 general X3's. They should fit the bill just right after some suspension changes.
Sent from my SM-J737A using Tapatalk
Replaced a flat tire after one got popped about 2 miles from my house. Not sure what caused the hole. But it punched through and stayed where it was...
