marty79
- Dec 2, 2015
- Newton, NC
Or is this where weight distribution hitch comes into play as wellSince Tahoe says 500lb tongue weight..
So since the tongue weight is 331lb, I need to load Jeep to where it's only adding just few more hundred pounds right? Since Tahoe says 500lb tongue weight..
right...so since it towed almost pretty perfect last weekend now knowing I had it too far forward according to these weights now, my tow rig should be able to handle this even better once I get some of this weight off the tongue.I am guessing the 500lb number you are talking about is max tounge weight on the hitch?
Wild guess here, but I would imagine having over max recommended weight on the hitch (331+couple hundred pounds) will squat your Tahoe to carolina stance levels.
I would imagine this would make the tow vehicle drive like poop?
You realize how tongue weight works, you cant have zero tongue weight. Jeep on trailer you had 300lbs?
I'm confused to why you're trying to change this? 500lb is the MAX, not what it needs to be. If it towed fine, leave it be. You need to place the load 60/40. That does not mean you must always have the max on the tongue. If your load was smaller/shorter then you may wind up putting everything in front of the axles to try to get to this "500lb tongue weight". Some loads may not even be possible to get to a 500lb tongue weight.
How many of us that tow regular break out a scale for the tongue weights? I know they have hitches with scales built in but can justify paying for one. I load it till it looks good and roll on. I have loaded it wrong before and just a quick adjustment forward or back corrects things.
Well trailer weighs this much..
How many of us that tow regular break out a scale for the tongue weights? I know they have hitches with scales built in but I can't justify paying for one. I load it till it looks good and roll on. I have loaded it wrong before and just a quick adjustment forward or back corrects things.
I do.
I have 4 hydraulic scales. 0-1000 lbs.
Hook trailer to tow rig, load trailer, measure loaded height of hitch.
Unhook trailer, put scale under tongue, set to same height. Check weight.
Move load front to rear for desired tongue weight.
I do.
Did you forget a zero? Or did I forget I was on the karting forum?I do.
Yep.So let's explore this, just to check assumptions. I'm assuming left both tires on one scale for the left side, both right tires on one scale for the right side, and the tongue jack on the 3rd scale?
no that 331 is just trailer empty weight.Jeep on trailer you had 300lbs?
I wasn't aware there are 2 numbers, but the numbers on this hitch are worn off. I just know from owning so many Tahoe 500 is usually normal max tongue.What's the tongue rating on the Tahoe with a weight distributing hitch?
dang it, should've done this while I had scales here stupid...lolI do.
this is how I've been doing it but since I'm working with a Tahoe that's not mine, borrowed, and I'm working with current setup which is these funky axles that I'm not used to, makes this trailer tow little funky (the tiny shake I had at 58-62). Having that said, I'm about 99% sure I had the jeep about 7" too far forward so I think placement will/should get it to pull as good as it did at 65mph at other speeds as well.It's not that simple with Fuller, remember the science of metals thing? I think most of us who tow on the regular know how to load a trailer by look and feel. Something I call the calibrated eyeball scale.
Yep.
I was just stating that the way I had it loaded, I "thought" my jeep weighed a heck of a lot more than 5000, and I thought the front also weighed a lot more than the rear so I was loading it like I usually do by 60/40 ish but now that I see actual weight, it makes me realize I had the jeep too far forward on trailer now knowing the actual weight and how much just the empty trailer tongue weight is.
