skyhighZJ
Thanks for your taxes
- May 31, 2012
- Aberdeen, NC.
I’m with you. Looks just like my W56 in my 4Runner except mine is an A. I think 300 is alright as long as the case is good. I bought a W56C and case the other day for 40bucks. He thought it was locked up but it was actually the case. It looked like he ran it without sufficient lubricantion. Talk him down to 225.View attachment 260784 So talked to the guy some more and he had misspoke. It is from the late eighties. Based on the site that @Bhudgins posted and looking at the pics I’m leaning towards a w56b model. It seems to match the pic that Marlin has on their website. Most notably the top shift tcase not forward shift and also there are the hex plugs in the middle of the case halves. What say you? And, if it is a W series with the t case is 300 a fair price?
That's the way mine is set up u bolt in the back holes never had a problem and I have the torque of duel cases so you should be fine with a single caseIf you use a w56 behind the 22r on a first gen a budbuilt crossmember will still bolt right up. The front holes of the crossmember will bolt up the the old rear holes, you can then run u bolts over the frame for the rear holes or weld on a bracket.
