Darkbloodmon
- Dec 21, 2020
- Concord, NC
3rd Gen Dodge front bumper of my SLT 2500 (Fancy) OEM fog light provisions, paint code PKJ : Light Almond Pearl, comes with OE mounting brackets and hardware. Fog lights don't work I chopped the harness for the pigtails to wire my aftermarket set to the OE harness, get your own cheap amazon LEDS for a 20year old truck. It has body dmg on the driver corner where it meets the headlight housing; paint transfer and a small dent. $125, can deliver within reason for fuel money.
3rd Gen Dodge hub caps (one is cracked), Includes a bunch of OE lug nuts, they are SAE, the later generation Ram 2500+ trucks are metric. $50
3rd Gen Dodge truck front brush guard unknown mfg. Will fit 1500s, got the truck with it bent in on the driver side tube rails from an impact, that transferred to the bumper listed above. Comes with Brackets and hardware. Again the mounting points are bent from an impact so it's not perfect. I've mounted and removed it multiple times no issue. $150 alone, $225 package deal if you take it with the bumper.
3rd Gen 4Runner rear axle assembly off a '98 limited 4x4 with ABS, Freshly painted in a flat powder coat, No third member. $125 takes it. Will deliver within reason for fuel money.
