- Sep 28, 2009
- Concord, NC
I have a chance to purchase this trailer new for $3,000. I'm wondering if this is a good deal or if there may be a better deal out there? To start with I'm pulling this with my 1/2 ton. I wanted to find the lightest 5 ton trailer I could and this one appears to be it. I'm a little concerned about it not being a deckover, but if worse comes to worse I could take the fender wells off. It is 8 feet wide though so it may not even be an issue. Please respond with your thoughts, comments, suggestions, etc.
By the way, I've already bought the Tekonsha P3 brake controller for my truck.
Trailer Brand: Hudson
Trailer Model: HSE18 DELUXE 5 TON
Trailer Year: 2010
MSRP: $3,539.00
Condition: New
Status: Available
Trailer Length: 18'
Trailer Type: Equipment Trailer Hd
Color: Black
Width: 8′
GVW: 12,000
Weight: 2,000
Axle: Tandem Axle
Standard Specifications
* GVWR: 12,000 lbs.
* Axles: (2) 5,200 lb.E-Z lube Dexter w/ Brakes
* Empty Weight: 2,000 lbs.
* Suspension: Multi-Leaf Spring
* Maximum Payload: 10,000 lbs. W/adequate hitch load
* Brakes: Electric 12" x 2" w/ break-a-way kit
* Overall Length: 24'
* Wheels: 15" x 6" White Spoke 6-bolt
* Deck Length: 18'
* Tires: ST 225/75 R15 8-PR
* Overall Width: 96"
* Jack Capacity: 5,000 lb. w/Foot
* Deck Width: 78"
* Main Frame: 7" Channel @ 9.8 lbs.
* Deck Height: 23"
* Crossmembers: 3" Channel @ 3.5 lbs.
* Hitch: Adj. 2 5/16" Ball Coupler
* Decking: 2" x 8" Treated Pine
* Hitch Height: 22" to 26"
* Tie Downs: 4" Stake Pockets
* Ramps: 4' Cleated Fully Adjustable
* Lights: DOT Approved w/ conduit
* Fenders: Diamond Plate
* Colors: Yellow or Black
Trailer Year: 2010
MSRP: $3,539.00
Condition: New
Status: Available
Trailer Length: 18'
Color: Black
Width: 8′
GVW: 12,000
Weight: 2,000
Axle: Tandem Axle
* GVWR: 12,000 lbs.
* Deck Length: 18'
* Deck Width: 78"
* Deck Height: 23"
