Finished my metal cloak copies that fit 43’s.
Turned down and tapped some Al lowers for the buggy bulld
Looks good, but those are too pretty for pliers. Put em in a mill and cut some wrench flats.
It won’t be long before they’re getting dragged over every rock in the east coast, but I probably willl toss some flats on em before it’s over.
Fri. I replaced the sway bar links and frame bushings on the 98 K1500. I can't believe what a difference it made w the ride and it stopped the steering darting when taking a tight, right curve at speed.It also cured the wandering on I-40 when it was windy.I had tightened the old links months ago but I think one joint was shifting in turns, the frame bushings were a bit loose too.
I also checked the pvc valve,it was dirty but not stuck i'm sure it was original.The grommet was stretched and the pvc just slid in and out easily and was not sealing. I got a kit w new hoses,the tube and pvc and a new grommet.I'm kicking myself for not replacing them sooner.The performance is amazing, more power and the trans. downshifts instantly when I mash the gas.It used to hesitate before and needed much more peddle before it would downshift.I'm sure i'll see a boost in the mpgs the next time I fuel up.
Picked up my new front driveshaft for the TJ from Oliver's. Dave is the man when in comes to driveshafts.
I just wish they'd return phone calls. Called up there no less than a handful of times trying to get a rear made and have yet to get a return call
PM them here on NC4x4. Ive order two shafts that way no problem, quick turn around.
Another cruise and another brake caliper locked up... I have lost count how many have locked up over the past couple years.
Sent from my SM-G965U using Tapatalk
Today was a snowball effect kinda day lol. I have a remote trans filter on the front passenger fender before the fluid runs to the cooler. I went to change it and when I looked down I could see down the exhaust pipe, because apparently a flange bolt broke. Get the filter replaced, start trying to replace the missing flange bolt and it's not completely missing, it's just rusted in half and seized in the manifold. Great, take the other flange bolt out and pull the manifold to get the bolt out. Find a broken manifold stud. F that, that project can wait. Get bolt out of manifold and put it back, get exhaust bolted back up, look down and notice one of the axle studs in the front axle isn't there. And of course it's not missing, it's broke off in the housing. I quit. And yes I wheel a giant tetanus laced piece of junk.
Duane
I washed the JKUR on Sunday. :cool: Wish I could wheel somewhere.
