jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
Looking for something Stock-ish for 99XJ. Needs to go over the rear axle and exit behind it. Nothing loud nothing fancy nothing shiny nothing expensive.
Dang! Good call. I’m pretty sure it’s the tertiary revision. I’ll double check.So you need to clarify which frame you have as there is a mid year change in the frame of 99s
Shoot me a message. You have your profile locked down so I can’t PM you.I have some cut off pieces that make it full minus the CAT. think I cut it in 2 pieces to remove, still have all the pieces. Had it bent up at Pon & rounds free to pick up.
How much power does the turbo add?I can't find a link right now, but I have bought 2-3 XJ cat backs made by Dynamax (Walker). Was around $125 last time through Summit. Fit really well. Had a turbo muffler, so sounded close to stock.
At least 250How much power does the turbo add?
Depends how many horse pressures it’s makingHow much power does the turbo add?
At the crank, 1.25 HP to the tarsAt least 250
Depends if you apply the provided sticker to the hatch glass to announce you’re HP gains.How much power does the turbo add?
Is that normal air tars or special nitrogen air tarsAt the crank, 1.25 HP to the tars
