untchabl
On the rocks
- Mar 30, 2009
- Bear Creek, NC 27207
Short work day but we got the steering column mounted and got the basics of the radiator mount done.
Any updates?
Been slacking on the buggy lately so spent some time on it this weekend. Got the power steering mount built and installed, it took a lot longer than I thought it would but I'm happy with how it turned out. A nice surprise was the stock serpentine belt still fits. Also got the winch plate drilled and tacked on. Small progress but couple more things checked off the to-do list.
who makes that bracket?
I built the power steering bracket. The fairlead mount is from Barnes4wd.
I was asking about the PS bracket. I hadnt seen one on the market for the 2.0/2.3 so was curious. Buggy is coming along nicely.
So when's the new piece of hardware showing up?
Interested to know how those over sized trunnion bearings work for you. I’m considering those vs the trail gear trunnion bearing eliminators.
Fantastic build BTW! Keep it up.
With full hydro, I think the Front Range parts are going to be a major upgrade in strength. With the steering arms being keyed to the knuckles it takes a lot of stress off the knuckle studs. Price wise it was about the same to go with the Front Range setup vs. TG 6-shooters and trunnion elimintator and I think I've got a stronger setup vs. the TG stuff.
Hope to have some more updates in the next few weeks. Get the new front housing mounted and modify the rear upper shock mounts. Also sent a stock Tracker t-case to a guy that modifies them and converts them into a doubler setup, so it will be a Tracker case in front and a Toyota case behind that. Plan is to put 4.7's in the Toyota case so I should have plenty of gearing options.
I totally overlooked the keyed steering arms. Those are trick!
Is there any machining involved on the actual knuckle for those?
