- Mar 24, 2005
- Stokesdale-Greensboro
My riding lawnmower has me stumped. I dropped a brand new 19hp single-cylinder Briggs engine in it March 2018, and it has run perfect for 8 months. All of a sudden, it won't start. It will crank and crank, just won't fire. Pull the plug, hold it against engine, no spark.
The fact that it cranks, tells me mowers safety switches (seat, brake pedal, PTO) are not coming in to play. Maybe I'm wrong?
Just for fun, I checked fuel; No change with ether sprayed in carb. The pump flowed fuel into a Gatorade bottle, which impressively ignited when I dumped it on a flaming paper towel. Fuel shutoff solenoid clicks when I disconnect/reconnect it.
I measured 5k ohm between spark plug wire and the kill terminal on the coil. Engine still will not spark with kill wire disconnected.
Is there anything else to check before I start throwing parts at it, i.e. new coil?
