jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
Just sold the wheels and tires off my jeep, and before I go and buy new wheels, I need to figure out what direction I'm going with the axles. My D30 is decently setup (cromo's, Teraflex hi steer, lunchbox locker, HD ball joints, some type of uber U-joint, 4.88's, Solid cover), and the 8.8 is basically stock with 4.88's, Solid cover, lunchbox locker. Here's my pros and cons, so tell me what I'm missing and add your collective wisdom.
D30/8.8 ($0/$0)
PROS:
-No work required
-No cost to upgrade
-Matching bolt pattern
-Lightest combo
CONS:
-Stock width (I prefer full width)
-D30 limits to ~35" tire
-8.8 needs different locker for street use (I hate the way it drives with the lunchbox)
D44/8.8
PROS:
-Bolt in D44 options
-Potentially wider track (Ford HP D44 or similar)
-Lighter than D60
-Best overall ground clearance if I run 37-38's
CONS:
-Limits to a 37-38" tire
-Heavier than D30/8.8
-~$2000 cost (offset by selling D30)
-Potentially stock width
-If wider D44 front, then 8.8 will have spacers/adapters
-Time and effort to build D44
D60/8.8
PROS:
-Full Width
-Heavy
-Plenty of strength for 37-38's
-Unlimited options for steering/gearing/lockers
CONS:
-Heavier than D44/8.8
-Diminished Ground Clearance
-~$2500-3000 cost (offset ~$800 by selling D30)
-8.8 will have adapter spacers
-Time and effort to build D60
-Packaging issues (I've done it before, so I at least know what to expect)
Superduty D60/Superduty D60 (both steering)
PROS:
-Full Width
-Extra Heavy
-Interchangeable parts
-4 wheel steering
-Cool factor
-Low COG (1/3 of the vehicle weight would be the axles!)
CONS:
-Heavier than pretty much everything
-~$8000 cost (offset ~$1600 by selling D30/8.8/NP231)
-Time and effort to build D60's
-Packaging issues
-Driveshaft issues
-Hydro steering issues
It seems to me the D44/8.8 would be the best overall option if I only plan to run 37-38's, leaning towards 37" Creepy Crawlers at this time. D60's would be more future proof though. Since i already have a pair of 5x4.5 to 8x6.5 spacer/adapters, I could go with a full width 8 lug D44 front, and use the spacers to widen the 8.8 to about 65-66". Would a 31 spline 8.8 hold up well to a 4.6 stroker, 100:1 crawl ratio, and 38" Creepys?
D30/8.8 ($0/$0)
PROS:
-No work required
-No cost to upgrade
-Lightest combo
CONS:
D44/8.8
PROS:
-Lighter than D60
CONS:
D60/8.8
PROS:
-Full Width
-Heavy
CONS:
PROS:
-Full Width
-Extra Heavy
-4 wheel steering
-Cool factor
CONS:
-Packaging issues
-Driveshaft issues
