And so it begins....
No thank you Alex and Carolina Truggies! I know it has been money well spent.
Looks nasty... Prolly see ya Saturday at Uwharrie.
-12 inlet -6 outlet
Iirc 1700 psi at 8 gpm gotta double ck the specs
I called and asked....
You might benefit from jumping up a line size at the pump. The high flow pumps are running -16 inlets and -8 outlets. It might help push the volume when sawing the wheel back and forth and keep the fluid a little cooler. Just a guess though.
Hoping the dual pumps will help with that also. I may change the suction side over for now and do the pressure one when the wallet heals some.
Ride with us sat at uwharrie? Alex is going to beat on travis's buggy too. :flipoff2:
Well guess i didnt see you guys because i has to deal with this after we got the springs on the shocks... Guess time for a set of reid racing outers.
Give a shout tomorrow, I'll hook u up with some Solid knuckles.
Dammit to hell bro.
And i know what it's like not to catch a winning scenario.
Even with the solids I would connect it to your highsteer arm. Be hard pressed to break it then. Have not been able to touch mine after doing it.
Harlan next weekend for fall crawl...
