fourtrax
- Feb 27, 2007
- Just below the Apex
Shop Clean Up - Miscellaneous fj80, mini truck, 4runner parts.
Everything is OBO, Pictures per request, Best contact is @4LowandSlow or 919-8six9-4seven3seven.
X4 sequoia wheels 17” $150
GX 6-lug rollers $50
3rd Gen 4runner/1st gen tacoma factory depo headlights, $50
FJ40 metal fan clutch shroud, $30
2x Eibach 1400.250.0100 springs $60
2x Eibach 1400.250.0150 springs $60
1st GEN 4RUNNER/PICKUP PARTS
1st gen 4runner top $100
1st Gen mini/4runner front axle shafts. (L&R) $50
1st Gen solid axle spindles ( pair) $20
x3 1st gen Rear NON IFS rear axle shafts $30
LROR custom T/C mount $30
22RE engine/transmission plate 5-speed $10
22re front timing cover with Oil Pump/Water Pump $20
22R Complete distributor w/ vacuum actuator $25
22re lower intake manifold with fuel rail $25
1st gen 4runner/pickup SR5 gray steering wheel $15
22re fan shroud, cracked at the bottom. $15
1st gen 4runner front plastic wheel liners with toyota mudflaps, $50
1st gen 4runner complete steering column assembly,(ignition switch, clockspring, switch assy) $50
1st gen 4runner heater core assembly with housing, $30
1st gen 4runner/pickup front headlight bezels (grey) one is cracked, $25
22re 1st gen 4runner airbox housing w/ MAF in good condition, $50
22re A/C bracket, $20
22re fan clutch with blade, $15
2x 1st gen 4runner gas tanks with sending units, $100 ea
80 PARTS
A442F 93-94 80 transmission factory new maybe 15k miles with aftermarket TC $500
A442F 93-94 80 transmission about 400K miles with stock TC $50
FZJ80 Steering box $150
FZJ80 stock springs, $5-
FZJ80 4” OME J springs, $200
4x FZJ80 Upper rear control arms, $15 ea
2x FZJ80 lower control arms, $20 ea
FZJ80 Factory transmission cross member w/ skid-plate. $50.99
Chinese FZJ80 Depe headlights with parking lights, $100
FZJ80 Brake pedal assembly, $50
2x 1FZ-FE fan clutch blades, $30 ea
FZJ80 power steering pencil cooler, $25
Factory FZJ80 VIP security system ECU
3fe vacuum switching valve assembly 135200-1440 $20
95-97 FZJ80 shifter bezel $50
95-97 Gray dash assembly with passenger side airbag $130
93-94 MAF (22250-66010) $100
FZJ80 complete distributor, $50
95-97 fzj80 center instrument cluster panel, $40
FZJ80 parking brake handle with cover, $30
1FZ-FE re-manufactured starter $75
1FZ-FE Denso Starter, $75
1FZ-FE Pair Valve assembly with tubes, $50
1FZ-FE Downpipes, Cats, Crossover frame 2-1 pipes, 93-94 $200
2x 1FZ-FE denso alternators, $50 ea
Homemade 1FZ-FE Harmonic balancer holder $27.53
80 PARTS
