Keith1138
- Nov 18, 2015
- Harrisburg NC
Want to wheel your xj? Dont want to drop thousands to build your front dana 30? I have a deal for you!!
-Dana 30 HP is set up for a xj, tj, zj...
-4.88 Gears
-Ecgs Chromoly axle shafts
-Yukon Grizzly locker
-Truss
-C-gussets
-Rock Jock Johny joint upper control arm joints
-Hiem style cross over tierod Knuckles drilled to 5/8
-Psc ram
-OTA Track bar bracket drilled to 5/8
-Lower control arms plated and drilled to 5/8s
-Solid Diff Cover
-Powerstop brakes
-Limit Strap tabs
-Spring perches were drilled and tapped for bump stops but the threads decided that didn't want to party. Just needs to be drilled one size up and re-tapped
-Timken Unit Bearings
-Spare set of ball joints
-Spare Axle Shafts
This axle has been wheeled on. The tie rod has a few slight bends in it from being wheeled hard. Axle is being replaced with a JK Rubi 44.
Nc4x4 price 1,000 dollars. Located in Concord Nc
-4.88 Gears
-Truss
-C-gussets
-Psc ram
-Solid Diff Cover
-Powerstop brakes
-Limit Strap tabs
-Spare Axle Shafts
