LS-Swapped Land Cruiser (FJ62)
adman02
Durham, NC
Selling my 1988 Toyota Land Cruiser FJ62. It is modified and ready to roll. Bought the vehicle a few years ago (listed on here) with the intention of building a family-friendly off road vehicle. Completed the LS swap, but have lost interest in it.
• Body has roughly 207,000 miles
• Engine (LM7) and transmission (4L60e) from a 2006 Yukon with about 186,000 miles
• Spring over axle lift with 35" Goodyear Wrangler MT/Rs, 4.88 gears, and a high steer kit
• New Toyota fuel tank and Tanks, Inc in-tank fuel pump
• Needs a few odds and ends to finish it, but it can be your daily driver if you want (even has working heat and AC)
• Body has no dents, but it does have rust spots (it's an old Toyota) and the seat vinyl is a little rough.
• Have a clean title in hand. Also have boxes of left-over parts if you want them.
New price: $14,500 $12,500
IMG_7101.JPGIMG_7102.JPGIMG_7103.JPGIMG_7107.JPGIMG_7108.JPGIMG_7109.JPGIMG_7110.JPGIMG_7111.JPG
I came here hoping I couldn't find it....
Gosh. Dangit. I don't even like Toyota's and this is tempting.
To keep it technical...
Will it do a wheelie if you strap a couple fat girls to the tailgate?
Stop.
@adman02
sidebar question....did you wire in a brake pedal switch to unlock the tourque converter? I haven't seen much on what is used, if its always needed, and how its mounted to the older style pedals that don't hav provisions for it.
Thanks!
@adman02
Thanks!
My LJ doesn't have the TCC hooked up. It unlocks based on speed and is all done in the tune. Works perfectly.
@adman02
Thanks!
I do. There are a couple of options for the land cruiser. BP Automotive (and other harness suppliers) make a switch you can swap/wire in.
Also, there's a guy named CruiserMatt on IH8Mud that makes a special wiring harness that unlocks the converter when the brake is pressed - no special switch needed. This is what I used.
I’ve seen it in person, and if times were different for me personally, I would have already bought it. Solid dude, good looking rig, free bump.
@77GreenMachine sounds like we already gots somebody that's put a set of eye on it.
