Travel trailer and 2 crawler trailer
Damuddog
Member
Sylva, NC
I’m all over the place trying to figure out how to tow a trailer big enough for 2 TJ based crawlers and having a camper or motor home. Class C’s don’t seem to have the towing capability and even a lot of class A’s don’t. I can’t afford the big boys that do. I want to use the camper also when we aren’t wheeling. My current truck is a 2017 GMC Sierra 1500 with the 6.2 liter motor. It has plenty of power for my 24’ loadtrail trailer and 1 TJ crawler. Wife wants her own now so I’m needing a bigger trailer. We have toyed with keeping this truck to tow a travel trailer and getting a 1-ton truck to haul the 2 crawlers. We also thought about building a crawler hauler with a slide-in camper up front and gooseneck trailer. That’s a big trailer though. Plus the slide-in would be cramped with the wife and 2 kids. Thoughts?
Then that's going to make things incredibly difficult to do without both of you driving something.
Your problem is certainly not a unique one. Several people here have solved it different ways
@shawn and @trailhugger have successfully managed to wheel 2 TJ's, while bringing the kids along for several years now
3500 drw, 8-9ft slide in and a 28ft bumper pull or a 36-40 ft goose with a slide in on the front. Either way will be a heavy setup. A slide in can be a little cramped but the newer ones have decent room.
Ton truck long bed possibly a dully, slide in truck camper (you can get them with slide outs) and a 32’+ bumper pull. That’s about the only way to do it with one truck.
If you go slide in, I’d definitely push for the dually. I pull a 34’ behind a SRW and use a weight distribution hitch setup. I wouldn’t add anymore weight on the rear of my SRW setup.
I am so surprised that the class C aftermarket hasn’t come up with a frame strengthening fix for this issue. It seems like a lot of people would jump on it. I saw a bunch of people hauling way more than they should when I went to Easter Jeep Safari. I’m just afraid of the insurance companies if something ever went wrong. They would blame me even if it wasn’t my fault.
How long are each of your rigs?
Only have the one now. 106” wheel base
So how long is it from furthest point front to back? I ask because my buggy is 12ft front of front tires to rear of rear tires and my buddies is 12ft-4ish inches. So both of ours can fit with a little room between the tires on a 26ft trailer. So depending on the length you may not need as long of a trailer as you think to haul two.
12’5” tire to tire. I have a front stinger that may or may not play into loading. I will need the new rig to confirm.
I know it sounds a little redneck, but the cheapest way to get what you want is a school bus. Its a little bit of work but you can make a camper out of the bus and that chassis will tow 2 rigs easy. It wont be a speed demon, but its hard to beat bang-for-buck.
I also think this would be an awesome way to go also.......
Int 4700. 26+ft of mobile wheeling in a box! - Pirate4x4.Com : 4x4 and Off-Road Forum
They both require a little bit of work though....
The wife and I were just talking about a similar truck and how to fit 2 rigs inside and then pull a camper. The box truck build that is.
Can you your wife comfrtoably tow he camper? If so I say you have her haul that, you buy a dually and a 26’+ GN trailer and haul both rigs.
Obviously this is more fuel, but even with a dually+slide in+ 2 rig trailer you will be down in low single digit mpg.
The two separate towing vehicles will be in the 10ish mpg range and when you get there you have a nice camper with more room, and you can easily unhook the truck from the camper and have a nice ride into town if needed.
If you do decide on 1 rig to tow all of it in one shot, dually without a doubt. Preferably an F450 or 4500 platform in the Chevy or Dodge. It can be done. But man the dual will suck, and if you ever need a tow with all of that you’ll need a second mortgage!
What’s your budget?
The 1500 isn’t realistically going to handle a slide in camper plus a 2-car trailer, so your going to need something else most likely.
If you look around, you can find toters/motorcoaches/super C RVs for a reasonable price, comparable or less than a new 1 ton truck and slide in camper.
Also, if you look around for an older Class A with a tag axle, many are rated to pull 15k + and can be reasonably priced. I’m looking at a Class A diesel pusher right now that is rated at 15k from the factory and it’s very reasonably priced. The only downfall is it doesn’t have dedicated bunks for the kids; some do but not this one. It’s no toter rated for 30k towing, but for the limited towing miles I’ll put on it, I think it will be fine.
Don't forget the gooseneck.
You buy a new F450 ($100k) and NICE slide in with slide outs, and a gooseneck long enough, by the time you pay to have the crane set the slide-out on it, you could buy a Renegade to do the work :cool:
I'm just bitching because the price of decent trucks have shot higher than the cost of my first house :shaking: That renegade is just a lottery win vehicle (which reminds me...need to run across the street and buy some tickets)
Realistically, you're looking at a 40ft trailer and a class a license to pull two Jeeps and a slide in on a flatbed. The camper is going to take up 12ft of bed (more if it's a rear door vs side door), plus 26ft for two rigs that are basically touching. The trailer is going to weigh 17-18k, and you'll have to pull the camper off to put it on the truck if you plan on taking it anywhere that's not Harlan/Windrock/etc.
A 40-45ft bus with a 26-30ft flatbed is over legal length for an RV. It would have to be tagged/titled as a commercial class A truck.
What’s your budget?
x2... here is a super C for example: 2004 super c
If you are ok with getting Class A's, you could pick up a cheap HD truck and pull whatever you want.
what about a wedge style 3 car gooseneck trailer behind a dually? could put a popup or small travel trailer and two rigs on it?
If you were determined, you could probably find a GN trailer long enough to goth both rigs and put a moderately sized travel trailer shell on the front. But that still requires a long ass GN trailer, a travel trailer/camper, and a different truck.
There really isn’t a cheap option. About the cheapest would be to buy a used U haul truck and convert it to a camper with a garage, then tow your existing trailer with one of the rigs on it and one inside the U haul.
For something already completed, some Super C RVs have garages but most are 10-12’. Finding one big enough for a TJ may be a tall order but may be a good option.
