YJ creeper trans. Swap parts
Discussion in 'Parts For Sale' started by shelby27604, Jan 12, 2019.
  1. shelby27604
    shelby27604 Well-Known Member
    Jun 6, 2013
    Raleigh
    Was going to swap the ax15 for a creeper gear trans. But the swap didn't get finished before I sold the Jeep.
    -NP435 from a Ford with 6.69:1 first gear
    -Ford NP208 and FSJ NP208 (was going to swap Ford input into the Jeep version, as it is compact enough for a YJ. 2.61:1 4lo
    NP208 has a fixed rear output.
    -T176 bellhousing, will bolt to the NP435 and 4.0l, will need to notch the bell for CPS if running factory FI
    -Waggy front and rear driveshafts, rear is a CV joint shaft, both are slip joint shafts.
    Selling individually for $750, will sell the setup for $600
  2. shelby27604
    Jun 6, 2013
    Raleigh
    Bump, someone has a blown AX15 and wants to upgrade.
    Parts are for sale individually, happy to make package deals too.
  3. JLS
    JLS New Member
    Tuesday
    Denver, NC
    Do you still have the transmission?
  4. shelby27604
    Jun 6, 2013
    Raleigh
    PM sent, I am down to one bellhousing, but all other parts are floating around somewhere.
  5. shelby27604
    Jun 6, 2013
    Raleigh
    pics
    Ford and Jeep NP208's w/ shifters
    Ford Wide ratio NP435 with adapter and shifter
    T176 bellhousing
    FSJ front and rear driveshafts (to be modified for your application)
    $600 for all of it.
    Remaining parts needed, clutch parts, modify bell for cps, and modify driveshafts as necessary. Double the crawl of your factory Ax15 YJ or TJ
Share This Page
