Trailer options
Discussion in 'Tow Rigs and Trailers' started by CLRracer, Aug 20, 2019.
  1. CLRracer
    CLRracer Mopar Nut
    Mar 20, 2005
    Archer Lodge
    Looking at getting another trailer, pretty much narrowed it down to a 24ft low deck gooseneck. The brands I'm looking at offer the 102" "buggy hauler" style with the drive over fenders. Initially my thinking was if I needed a wide trailer I should just get a deck over, and most of what I'll be hauling will fit between the fenders, so I never really looked at the buggy hauler style. Thoughts? It is a decent bit cheaper than a deck over.
    Second, single or dual landing gear. Most come with single, and every trailer I've ever had or used was a single, but if the dual is worth the cost I might as well get it while I'm ordering.
    Any other options you wish you did or didn't have on your trailers? Mostly I'll be hauling trucks and tractors, occasionally materials like steel or lumber but not nearly as much as vehicles.
    Duane
  2. Stuntman Autoworks
    Stuntman Autoworks Instigator of things
    May 6, 2010
    Sanford NC 27330
    Depending on the tow rig I prefer a tag trailer for 24' and less. Dual jacks are nice to keep the trailer from leaning if you unhook and the load is heavier on one side vs the other.
    jeepinmatt likes this.
  3. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Also get a tilt trailer. I wish I had bought mine 10 years ago.
    Loganwayne and jeepinmatt like this.
  4. Croatan_Kid
    Croatan_Kid How's your hammer hangin'?
    Nov 4, 2007
    New Bern
    I prefer equipment trailers (low deck) , but deckovers definitely have their place.
    The second jack is worth it. It was another 140 bucks when I built mine. I couldn't stand the thought of unhooking the trailer with it loaded and only having one jack. Plus, you usually get a bigger single toolbox between them instead of a box on either side of a single jack.
    Tilt trailers are nice, but they also have their place. If you're loading something with a long wheelbase, it'll want to tilt if the front tires pass the breaking point and there's no way to lock it. It was also much easier for me to limp my excavator on a fixed trailer when it split a track, but that was a one time kinda thing.
    If it has fold down ramps and stiff knees, the spring assist is worth it! Ramps are heavy as shit.
    Oh, pony up for 17.5" tires/rims. Hands down my favorite upgrade. 8k axles, a little bit bigger brakes, and a helluva lot heavier tire. Don't listen to the stories about trying to find a spare on a Sunday afternoon on your way home from somewhere....you likely won't have a blow out since they'll probably never be overloaded :D
  5. BigSouth
    BigSouth Doesn't play well with others!
    Jun 8, 2011
    Shelby, NC
    Wasn’t aware this was the only road hazard that takes out tires.
  6. BigSouth
    Jun 8, 2011
    Shelby, NC
    I’ve had 2 “buggy haulers” with the drive over fenders. The only use you listed that might offer some irritation would be hauling steel or lumber. The fenders get in the way of loading and unloading with a forklift. I decided to stay away from gravity tilt trailers because I can’t leave anything stock for very long. Just bolting on a spare tire mount screws up the engineers math for a balanced tilt. Powered tilt... not an issue, but more $$$. And I vote normal size rims and tires for convenience. More than once, I’ve looked for a tire after hours (mine or somebody’s in the convoy). Ain’t worth the hassle.
  7. CasterTroy
    CasterTroy Motarded
    Mar 21, 2005
    Wallburg
    I saw the part about balance and spare mount... but dang....do you get all cocky n'shit when you go 17.5" and say to hell with carrying a spare (or 2)?
    Tacoma747, jeepinmatt and BigSouth like this.
  8. BigSouth
    Jun 8, 2011
    Shelby, NC
    True story... Convoy to Harlan, KY for the 4th, @Paul lost a trailer tire. No biggie, we did our best NASCAR tire change and were back on the road in no time. Less than 30 minutes later, the spare we just put on blew. We were in nowhere BFE and Paul finds a shop with 2 used tires that fit the need. I promise you there weren’t any used 17.5’s in ol’ boys shop.
    77GreenMachine and Paul like this.
  9. CLRracer
    CLRracer Mopar Nut
    Mar 20, 2005
    Archer Lodge
    @BigSouth was there ever a time you didn't like the extra width and thicker fenders, or conversely a time you were really glad you had it?
    As for tilt, if I could get one where the whole deck tilted I would consider it, but most are split deck, and tilt starts to put trailers out of what I'm looking to spend.
    Thanks for the input.
    Duane
  10. BigSouth
    Jun 8, 2011
    Shelby, NC
    Always like the extra width and I love the thicker fenders. You can stand on them, they don’t get damaged from tire shrapnel, and they’re an extension of the rub rail. I’ve leaned mine against a tree in a tight spot to pivot the trailer. Other than side loading material with a forklift, I don’t think you’ll ever regret getting the HD drive over fenders.
    CLRracer likes this.
  11. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Hydraulic tilt doesnt lower until you hit the button and most gravity tilts have a valve you can lock so it doesnt go down until you want it to. I have dragged quad cab duallys 15 passenger vans and all kinds of tractors on it with no "lowering issues". I've also pulled plenty of broken down equipment on it with no issues at all. Mine is 24ft long and the whole 24ft tilts with a 12k lb winch mounted to the front of the deck.
  12. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Mine is full length hydraulic tilt, 24ft of never having to mess with ramps greatness.
  13. BigSouth
    Jun 8, 2011
    Shelby, NC
    I decided against tilt because I need the ability to side load a golf cart on the front and also load a vehicle on the rear. I also have weight restrictions with the RV. Something I never experienced before I sold my Cummins. :D
  14. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    If you have alot of different width stuff to haul the tilt is also nice because you never have to slide ramps around to get the right width.
    drkelly and jeepinmatt like this.
  15. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    That can be fixed with a tilt that has a fixed front section.:eek:
  16. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Only thing I want to do to mine is raise the deck about 5" till its even withthe top of the fenders and make the deck 96"wide
  17. BigSouth
    Jun 8, 2011
    Shelby, NC
    There wasn’t a perfect fit anywhere on the market. It was gonna have to be custom ordered. My needs steered me away from it. I’m not arguing one trailer is better than the other. The more I studied it, the more I realize that there is no perfect trailer that does it all. Pros and cons to every style.
  18. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Deffinatly i just had tti give you a hard time.
    BigSouth likes this.
  19. GLTHFJ60
    GLTHFJ60 Well-Known Member
    Aug 17, 2012
    Durham, NC
    I just went through this late last year. Was considering getting a buggy hauler for my wide wheeler (full width wontons with wide 42s). I decided against it because to get the tongue weight right I would have had to park on top of the fenders during transport. I didn't like that idea.
    I ended up getting a deckover with spring assist monster whatever ramps for a good deal. No regrets. It being high up makes it really, really easy to hook up straps. Higher center of gravity doesn't seem to make a difference.
    NCJeeplover likes this.
  20. jeepinmatt
    jeepinmatt Still Fat
    Mar 24, 2005
    Stanley, NC
    Dont even bother, I had this argument with @Croatan_Kid last time the topic came up and he still thinks it's easier to go up 2 ramps instead of 1 big one :p
  21. StretchASU
    StretchASU Well-Known Member
    Oct 17, 2006
    Creedmoor, NC
    FDWTG-7K-24D 24 ft. (10 ft. fixed + 14 ft. 6 in. tilt deck) $5,490.00
    +140 for dual Jacks
    +380 for Cooper Discoverer HT3 tires
    +285 for Cooper Discoverer HT3 spare
  22. Stuntman Autoworks
    May 6, 2010
    Sanford NC 27330
    Just can't tell some people anything.
  23. Jody Treadway
    Jody Treadway Croc wearing fool Moderator
    Mar 20, 2005
    Hendersonville, NC
    I love my buggy hauler low boy. The extra width is great loading and unloading a full width rig.
    No regerts
  24. Croatan_Kid
    Nov 4, 2007
    New Bern
    It's certainly not any more difficult... :flipoff2: I did seriously consider a tilt, but price won out. I'm also not sure if they made a full tilt gooseneck. I know I asked if they valved them so they could lock in the tilted position and they didn't. Sure, I could have added it myself, but I certainly don't regret the trailer I wound up with.
    It's not, but it does contribute to a lot of blowouts.
    Who doesn't carry a spare? :confused:
    CasterTroy likes this.
  25. Croatan_Kid
    Nov 4, 2007
    New Bern
    The full tilt is definitely the way to go if you go tilt. I've seen a handful of brands that didn't have valves on them to lock them, but that could always be added. The ones I've seen kick up were the fixed front deck with the rear tilt section.
Share This Page
