Trailer deck screws
Discussion in 'Tow Rigs and Trailers' started by YotaOnRocks, Jul 7, 2020.
  1. YotaOnRocks
    YotaOnRocks Well-Known Member
    Jul 17, 2007
    Winston-Salem
    About to put a new deck on our old 10ton Hudson trailer. Any recommendations on the best screws to use? Any installation tips? TIA
  2. Junkyard Dog
    Junkyard Dog Well-Known Member
    Mar 21, 2005
    Sanford, NC
    Floor torx screws. Pop a hole and shoot em in. More than likely what it had from factory
    rodney eppes, BigClay and CLRracer like this.
  3. paradisePWoffrd
    paradisePWoffrd Recovering Project Junkie
    Nov 5, 2005
    Newton, NC
    YotaOnRocks and shawn like this.
  4. shawn
    shawn running dog lackey of the oppressor class Administrator
    Mar 13, 2005
    Raleigh, NC
    This. You might be better off shopping around for a shorter (2-1/2" screw) in a bigger box to get the cost down (Lowes and HD only sell them in the small boxes), but that's the kind of screw you want.
  5. Ron
    Ron Dum Spiro Spero Moderator
    Apr 16, 2005
    Sharon, SC
    Just for a contrarian point of view.
    When we built our homemade trailer 20 years ago we used carriage head bolts with the square shank. predrilled the board to just under the thread diameter, drilled the cross member to actual diameter and drove them through and sucked them down with nylocks.
    I probably wouldnt do it that way again, but its been 20 years and the OG boards are still on there and they are still holding and no cupping.
    We also just used lowes treated lumber
  6. jeepinmatt
    jeepinmatt Still Fat
    Mar 24, 2005
    Stanley, NC
    Disappointed. Thought this thread was gonna be about how much the ladies got aroused by guys with trailers.
  7. drkelly
    drkelly Dipstick who put two vehicles on jack stands
    Mar 21, 2005
    Oak Ridge/Stokesdale, NC
    That is EXACTLY what I did on my 5x8 utility trailer 30 years ago. The boards are still in place, but starting to fall apart a little.
  8. shawn
    Mar 13, 2005
    Raleigh, NC
    That sounds like it took forever.
    Related, it seems that a lot of trailer manufacturers don't (didn't??) use treated lumber on their trailers. If the trailer sits out in the sun and isn't loaded all the time, the wood dries out and holds up fairly well. If the trailer has shit sitting on it all the time, the wood rots in a big hurry.
  9. Ron
    Apr 16, 2005
    Sharon, SC
    Not really.
    Longer than just zipping a screw in sure. But we laid the boards in place where we wanted them.
    I think we used 3/8 bolts. So we ran a 5/16th bit through the board and metal frame on both ends. Sat the boards off. Then upsized the metal holes.
    Tapped the bolts through and impacted the nylocks on.
    I was 21 and broke at the time so time wasnt real valuable either. If I had to guess the whole process probably took about 2.5 beers. (thats also how I told time back then)
    jeepinmatt likes this.
  10. Fabrik8
    Fabrik8 Overcomplicator
    May 27, 2015
    Huntersville
    If the trailer was originally built with carriage bolts or whatever, and you're replacing the decking with the same type of decking and re-using the same holes, just use the same method. If you're changing something about the decking and are drilling new holes, use something different if you want.
    It's hard to go wrong with carriage bolts and Nylocs if that's what you're replacing. I sure as shit wouldn't buy them from Lowe's though, I'd order them from someplace that sells something worth using (McMaster, lots of other places). You'll get far better fastener quality and it will be cheaper.
  11. paradisePWoffrd
    Nov 5, 2005
    Newton, NC
    I have a 12ft trailer that was basically done the same way, 40 yrs ago when built. I helped my dad replace the deck on it ~20yrs ago and all the bolts were rusted. Had to cut/bust the boards and bolts loose. He wanted to reinstall the new ones the same way, using the existing holes. It sucked, but wasnt hard. The boards are now fallen apart again. I will likely use the screws this time around.
    Ron likes this.
  12. CasterTroy
    CasterTroy Motarded
    Mar 21, 2005
    Wallburg
    Damn.... @Chris_Keziah can mow 1/2 his yard in that amount of time
  13. 77GreenMachine
    77GreenMachine Phillip Talton
    Mar 30, 2010
    Trinity, NC
    Related question: my gooseneck was redone by the PO with new treated wood. He didn’t screw the boards to the cross member, it just has metal slats holding them by the ends in their respective place. Trailer is pretty flexy, I imagine it would give it quite a bit more rigidity if I screwed the boards down correct? Should I even bother?
    rodney eppes likes this.
  14. paradisePWoffrd
    Nov 5, 2005
    Newton, NC
    I wouldnt bother. You might could add a strap across the center of the boards, if you feel the ends arent enough to hold them.
    I dont believe that the screws would give it any strength. If you want to reduce the twisting, a torque tube is the only real way.
    77GreenMachine and shawn like this.
  15. shawn
    Mar 13, 2005
    Raleigh, NC
    Probably not.
    77GreenMachine likes this.
  16. rodney eppes
    rodney eppes Well-Known Member
    Feb 3, 2010
    Mt.Holly NC 28120
    I would think a goose neck would be twisty. I watched a few You Tube's on re-decking, & 1 guy had a real cheap trailer. Without the boards screwed down, it Really twisted! But a well built trailer I don't think would.
    From watching 1 video, I used torx self tapping deck screws. Don't know the brand now, but this guy said they would tap & drive into the crossmembers. I ordered them through Fastinal, & they let me order 50, I think it was. They look like the Teks sheet metal screws per Paradise Wolf, but with torx head. Them SOBs, didn't self tap into My cross members! After I wore out a couple & broke a couple, I Did pre-drill the holes. And still I used a impact to drive them! Good luck!
  17. paradisePWoffrd
    Nov 5, 2005
    Newton, NC
    If you think about how a trailer is designed, the only thing that is going to keep it from twisting is a torque tube. When you strap a vehicle down to it, the rigidity of the vehicle stiffens it up a good bit.
    rodney eppes, Ron and shawn like this.
  18. jeepinmatt
    Mar 24, 2005
    Stanley, NC
    Or a steel deck ;)
  19. shawn
    Mar 13, 2005
    Raleigh, NC
    Meh... no section depth in an 1/8" sheet.
  20. jeepinmatt
    Mar 24, 2005
    Stanley, NC
    Torsion is all about the shell. Depth dont matter much.
  21. shawn
    Mar 13, 2005
    Raleigh, NC
    That's deep.
Share This Page
