New Jeep Project, part 2
Discussion in 'Build Threads' started by yager, Dec 23, 2018.
  1. yager
    yager Better Faster Stronger
    Mar 17, 2005
    N. Raleigh, NC
    Getting a updated drive train.
    1) 3800 Buick Engine - Getting a different motor
    2) 4L60 GM - Rebuilt transmission
    3) Atlas 3.8 - Transfer case [ East Coast Gear Supply ]
    4) PCM Wiring and Bench Harness - Basically that
    5) Profit
    1) 3800 GM (Buick)
    Hey it fits......up until this point, i thought it would fit, i took measurement, but......
    There about were it will ruffly sit.
    I still have to re-gasket it. I don't mind going through the motor,
    it give me a good base line of where everything is at.
    The old water pump looked new, but the outside it look like it has been setting a while,
    ~10 years I know that this is TRUE....
    plus, Dex-cool still in the bottom of engine. (eww orange stuff, i hate it)
    Oil Filter Adapter - see below....
    Superchager -
    [X] order some parts - insert thing and some PAG, stinky oil
    Wiring Harness - (see pic)
    Stip out unneeded wires and sensors that will not be use.
    Move the VSS towards the transmission stuff. Much better for a RWD vs a FWD
    Move the batter cable out to a much better spot.
    Inspect it and re-wrap it. Cause I easily can test each wire to it known spot, (Its almost 20 years old)
    ...more coming...
  2. yager
    Mar 17, 2005
    N. Raleigh, NC
    2) 4L60e Transmission
    60 deg pattern,
    I4/V6 come this way, more/less
    plus a like the transmission come in 3 parts now, the front part is 9-3/8" for I4/v6 and v8. (checked myself)
    Converter - 27 spline
    2000-ish Stock Camaro 3800, converter, stall is ~1800 rpm,
    GM58CHD Diameter 10.375 pilot +1.5 spline 27, BC 9.875, Medium 1800-2000 Stall,
    [A Torque Conv./iso valve, has been install/trans guy]
    On the rear end of it, go with the adapter from Advance Adapters,
    Chase is a great guy, [insert web link here], I have know him, when he was out of a 2 car garage.
    The 4L60e, the rear adapter come with a 300m shaft for the tranny that has to go in, during the rebuild.
    It is 23 spline output the mat(jeep) [i had 27 spline ]
    shorten to ~2" past the rear flange (?), and it has a VSS on it to.
    [insert guy/gal who rebuild my trans]
    Atlas Adapter
    more coming
  3. yager
    Mar 17, 2005
    N. Raleigh, NC
    3) Transfer Case
    Atlas, 3.8 Ratio, passenger drop
    [X] Ordered, From [East Coast Gear Supply ]
    [X] Got it. :)
    [ ] Mocked up
    [ ] All set
    Adapter - 4L60e to Atlas, Short as short gets.....1.70" long, VSS goes right on top.
  4. yager
    Mar 17, 2005
    N. Raleigh, NC
    4) Profit
    orange150, trailhugger and shawn like this.
  5. Blkvoodoo
    Blkvoodoo professionally useless Moderator
    Mar 16, 2005
    Archer Lodge
    notice the pulley for blower is considerably smaller, blower is quite over driven, 15-18psi boost under full throttle (meth/water injection as well). motor is bone stock otherwise, it’s in a mud racing truck, so it only sees about 20-30seconds of full throttle at a time, the 3.8 is a tough engine to beat on. it’s also got a NOS fog system on it that was in process of being dialed in at the time the pic was taken. 376EE47C-3E62-4737-B933-393821095BEC.jpeg
  6. yager
    Mar 17, 2005
    N. Raleigh, NC
    I have thing on.....here
    Found it.... GM 24500345 :) now find it, uggu
    02/21/2019 - I found it. Ebay comes through!! I hope the grime protect it on it way here!!!
  7. Lee
    Lee ECGS
    Mar 20, 2005
    Rougemont NC
    Nice Mike! If the motor came from ECGS then it was the one @stinkbomb had. He bought it from @Blaze iirc.
    Sent from my SM-G950U using Tapatalk
    Jody Treadway and Mac5005 like this.
  8. yager
    Mar 17, 2005
    N. Raleigh, NC
    Blaze - hehe I'll send him a message, thanks Lee
    Mac5005 likes this.
  9. Creekin
    Creekin Well-Known Member
    Jun 26, 2018
    Hickory
    Nice work, how much HP / Torque?
  10. yager
    Mar 17, 2005
    N. Raleigh, NC
    Stock, I not going to do anything to it.
    I think it makes a ton of torque /hp
    Just clean it up a little,
    help it breath, dump the EGR etc.
    240hp/280 torque
    drkelly and TJ Will like this.
  11. 02dmax
    02dmax Well-Known Member
    Apr 23, 2007
    Raleigh
    Sweet. Like the engine choice!
  12. yager
    Mar 17, 2005
    N. Raleigh, NC
    The farther I go, the less i see anyone doing this on the 3800
    So i see little teed-bit here and there so im going to put thing here as i read them or deduce them.
    Many sites that have information is gone,
    this stuff is not rocket science but 10 years later, you still need something to go on.
    This may appear that i just did this, when in reality it just me posting it.
    1. Re-pin or take out, my harness.
    Done, Not hard, just time consuming.
    I found an older 3800 stuff be a Fiero guy for a SC
    and his was 99% dead on for my 2000 Pontiac wiring harness.
    (GM Wiring Diagrams and Pinouts)
    I also found a Camaro wiring harness it was 60% on,
    2. Bench Harness
    After a trip to LKQ with some PCM harness clip, empty them of all wires, much easier to start with.
    V8 guys/gals you all set with 100s of videos depicting how to do it.
    3800 not so much......
    3800 uses the same PCM as V8 do, but they are pinned 80% different, (thumb in the air, measurement)
    I only had to use the BLUE connector that plug into the PCM
    Here are the PINs i used.
    PCM C1 BLUE Connector
    15- TAN, Serial Data (UART)
    16- BLK, PCM Ground
    19- PNK, Ignition Voltage
    20- ORN, Battery Voltage
    56- BLK, PCM Ground
    57- BLK, PCM Ground
    59- PPL, Class 2 Serial Data
    60- BLK, PCM Ground
  13. yager
    Mar 17, 2005
    N. Raleigh, NC
    So....today I pulled the .BIN of of the PCM, yah!!!
    The HPtuners show up the other day,
    i aslo got the importent thing off the PCM
    like the PCM number #12201791
    and the vin number etc...
    The bench thing i whipped up works awesome !
  14. ORV design and fab
    ORV design and fab Well-Known Member
    Jul 11, 2009
    Raleigh area, NC
    If you ever need another set of hands. Give me a shout! Love the upgrades you are doing!!!! I see myself doing them someday
    yager likes this.
  15. a_kelley
    a_kelley mechanical fixer
    Jan 26, 2010
    Rutherfordton
    If you need/want factory diagrams, pm me.
    Jason W. and yager like this.
  16. yager
    Mar 17, 2005
    N. Raleigh, NC
    Anytime you want to stop over.... really !
    I 'think' im alright, i have found the FSM [wiring] online. But thank you...
    ORV design and fab likes this.
  17. yager
    Mar 17, 2005
    N. Raleigh, NC
    Yesterday was my last day of working on this for a month lay-off.
    Due to getting ready for at right hip replacement.
    Stopped warfin (oh no!!!)
    But i left it in a good stage, where i can go out and 'look' at it, :)
  18. obullfish
    obullfish Carolina Trail Blazers
    Nov 21, 2011
    Candler N.C.
    Good luck with the hip replacement @yager
    drkelly likes this.
  19. yager
    Mar 17, 2005
    N. Raleigh, NC
    ahhh ain't nothing.... i had hip hip 'worked' on when i was 18, broke my hip and repositing them, in the socket, plates/pins (those came out)
    Doc said running it, till ya can't (my words), i had a left hip replacement done in September, it was hurting more than my right....
    The right side would probably hurt more, but i don't fell much due to the stroke, 50-60%,
    oh well, this is good, been looking forward to it in sometime.......
    HANO likes this.
  20. sammi_davis
    sammi_davis Sawzall Surgeon
    Oct 23, 2005
    Eden N.C.
    Holy jeebus Mike , fast healing to ya my friend.
    336wheeler likes this.
  21. skyhighZJ
    skyhighZJ Thanks for your taxes
    May 31, 2012
    Aberdeen, NC.
    Take your due time off and get back at it when you’re able! Good luck and speedy recovery. This thing your building is very cool (different, unique) excited to see it continue!!
  22. ORV design and fab
    Jul 11, 2009
    Raleigh area, NC
    Sorry to hear about surgery. If you need anything give me a shout. I'll be praying for speedy recovery and for you to be back in the shop asap!!! Good luck bud
  23. yager
    Mar 17, 2005
    N. Raleigh, NC
    Got the old (motor mount) frame attached, off.
    Now i can pre-position the motor a bit... ;)
  24. yager
    Mar 17, 2005
    N. Raleigh, NC
    Drill out the 8 bolts the hold the flex plate on.
    Drill to M10x1.25 (not the 1.0)
    I do not know who made them 5/16, it was a good idea on paper but......
    Shows the difference between 5/16 and the M10
    All went well and I double the torque setting from about 25 to 50ft/lb
    Yes i chose to go with a 10.9 rating vs a 12.?
    The difference was negligible. ~10lb torque.
    Its like using a grade 9 vs a grade 8
    All in all, I would have just order the flex plate from a normal parts place.
    Stay away from RockAuto when it come to these parts....
    I had to take my screw driver and hammer and remove gobs
    of mis-starts, buggers and balls of shit... A tell tail of a newbie welder....
    doc, YotaOnRocks, amcjeepman and 3 others like this.
  25. yager
    Mar 17, 2005
    N. Raleigh, NC
    I figure i should post this. It been in the jeep awhile ~1.5 years.
    Work nicely :)
Share This Page
