2005 Rincon 650 Gas in Oil
gamnam12
Member
Whiteville, NC
Good afternoon everyone, I have a 2005 Rincon 650cc that is getting gas in the oil. Anyone know what could be causing this? I think that it may be a needle valve stuck open in the carb but am unsure. Wanted to see if anyone on here could help me out.
Thanks,
Aaron
Sounds like your on the right track its flooding out and that's what's causing it so the carb would be a great place to start
I worked on a 450 foreman that had the same problem and i rebuilt the carb and cleaned everything good and it hasnt had a problem since.
yep, you problem lies in the carb. sounds like the needle valve is stuck open or float out of wack. more than likely its the needle valve. whether its trash or a bad needle
Thanks everyone for the replies, that was my problem. Rebuilt the carb and it is running like a champ now.
Thanks,
Aaron
