JSJJ388
GREEN GREMLIN
- Aug 31, 2016
- HAMPTONVILLE, NORTH CAROLINA
there isnt any issues with it, if you only want single phase. You need to figure out how long, and how much power you want to have out there, to determine what size wire you need. Also need to make sure you get wire that is designed for direct bury or, my recommendation, place a pipe to put it in. I recommend placing multiple pipes out there. That way you have a chase if you decide to run water or comm to the building, or upgrade the power.
110 single phase is enough for what I do now. running pipe is the plan. I intend to run at least cold water out there for a spigot and a sink.
