Go Back   NC4x4 Forum > Photos > Build Threads
Welcome to the NC4x4 Forum!
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact us.
Reply
Thread Tools Display Modes
Old 05-04-2009, 10:34 AM   #1
SHINTON
Bondota
As much as this goes against everything we normally do, Dad and I did some "back alley" work this weekend on my 85 Toyota.
Why? Because it really does not make sense to fab up lots of new metal for every rust hole on a trail rig that I am gonna end up putting against a tree or on its side anyway!
Another reason it...we want to see how well it DOES hold up when I do hit the proverbial tree. Bondo gets a really bad rap at times but the stuff is pretty incredible, and after the 46 Willys rebuild, it literally holds up over 30-50 YEARS in some cases!!
So here is the concept. Yotas all seem to rust out along the body seams on the beds, mine is no exception.
S104u spent a bit of time and really did a killer job on replacing and welding in a panel on the passenger side. He also did a bang up job welding the shortened bed on the rear, those welds were BEAUTIFUL!
I am trying to get this truck ready to paint...and quickly and see other excuses above.
You will see we spread the bondo onto a piece of newspaper, and applied that to the large holes. We allowed it to setup for a few minutes and then peeled it off.
We kept applying the bondo to the smaller holes (using cardboard a few times for small holes to keep it in there) until everything was filled in.
We kept filing it all back down, and shaping it with our sander, etc. Dad will be doing the final shaping this week - re-adding the crease on the body and prepping / putting it all in primer.
Paint job should be in the next week - will update this thread then!
SHINTON is offline   Reply With Quote
Old 05-04-2009, 10:36 AM   #2
SHINTON
More pictures of the process...
Old 05-04-2009, 10:36 AM   #3
SHINTON
And more
Old 05-04-2009, 02:00 PM   #4
topless toy
That is a cool trick, but I have used the stuff that is fiberglass gel with the hair in it. Man does it work good at clinging onto the holes and is very quick when filling in large spots. Another good idea is to por-15 behind the iner bed panels to keep the rust away.
topless toy is offline   Reply With Quote
Old 05-05-2009, 09:10 AM   #5
SamHintonSr
The ol'grump with the gray hair says
Yup!!! The fiberglass with the hair + some rust inhibitor probably works just as well as "welding in a metal patch." It is just that "we CRAFTSMEN" can not bring ourselves to admit that we would ever do sucha thing - I have fixed holes bigenough to put your head through and saw the car 3 years later and it looked good AND the owner (who knwe how I fixed it ) was very happy.
SamHintonSr is offline   Reply With Quote
Old 05-06-2009, 06:58 PM   #6
jeepn-jason
I use duraglass and rage body filler religously on projects at work. I dont do bodywork but fiberglass kickpanels, doorpanels, speakerboxes ect. Rage brand body filler will sand a billion times smoother than bondo brand in my experiences. Its not that much more money either. Using fiberglass mat would have been another solution on those holes as well, and that stuff is tough as nails. As long as the rust has been treated...ie gone, it should hold up for a very long time. Cant wait to see the final product.
__________________
CJ5 tons, 39s caged
jeepn-jason is offline   Reply With Quote
Old 05-07-2009, 06:58 AM   #7
olejunky
I use rage and rage extreme and havent found anything i like better. I use it on everything i do anymore
olejunky is offline   Reply With Quote
Old 05-11-2009, 02:16 PM   #8
SHINTON
Some more updated pictures - all the holes are filled in and primed! At some point in my near future, lots of sanding, priming the whole truck and then painting!!
To recreate the body crease, a piece of wood is taped in place and then the body filler layers are "built up" to it, creating that little ledge!
Old 05-11-2009, 02:20 PM   #9
SHINTON
More pictures
Matches the original crease, NOT "show/perfect" but certainly gives the right illusion. You will notice the crease / "body line" where the two parts of the bed meet goes all the way to the lip of the wheel well. That too is just a mark inserted into the filler and then a bit of sanding.
Those little touches makes it look closer to normal, less likely to "see" it and know it is filled in with bondo.
Old 05-11-2009, 02:25 PM   #10
SHINTON
Ready for final sanding and then painting!
Old 05-28-2009, 01:42 PM   #11
SHINTON
More sanding and the first set of stripes on there!
Behind the stripes on the rear of the bed will be silver. In front of the stripes / the cab, etc will be white.
Have not done it yet but the "bulge" in the hood will be silver as well with thin red/black stripes around it.
Old 05-28-2009, 01:55 PM   #12
OracleMSU
Wicked. I'm definitely feelin' the design. Nice clean lines, retro look. Need to see this thing when it's done.
OracleMSU is offline   Reply With Quote
Old 06-02-2009, 01:49 PM   #13
SHINTON
A few little items to finish it!
Thin red/black stripes down the hood and repaint bumpers / rails black. Finally TRD Offroad stickers going on the rear.
But otherwise she is about done!
Sure came a long way from the dirty white & rust motif.
Old 06-02-2009, 02:10 PM   #14
BigRedB2
BigRedB2's Avatar
looks much better than when you started.
__________________
The United States Constitution (c) 1791. All Rights Reserved
[O(===)O]
'78 Bronco
BigRedB2 is offline   Reply With Quote
Old 06-02-2009, 02:15 PM   #15
Dylan W.
Dylan W.'s Avatar
Looks sweet Sam. Good job to both you and your father!
__________________
ECORS Racer #14
Sponsored in part by my friends at:
Snider Automotive
Snappy w/ Snap on Tools
YOUR HOT DOG GUY 336-768-8504
M&M Offroad 336-909-2076
Olivers driveshafts 336-724-1021
Mud Pro Metal works
RIDES of Conover 1-828-465-3800
Larry's Muffler Shop 1-828-635-5426
Jody Childers @ Stuck on Graphics
Mbalbritton Crazy 8 Graphics
Dylan W. is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2005 - 2010, NC4x4, LLC
[Output: 83.48 Kb. compressed to 75.95 Kb. by saving 7.52 Kb. (9.01%)]
