Added the armor I got from @Joe J. After I got it back from Exotics Powder coating in Kernersville.
Did your rear come with the "L" brackets that tied the frame to the bumper?
Mine came with bolts but JUST bolts. I was looking for the same thing they provided with d-ring mounts
No. I had a set already from Barnes. The DS is welded in, but the wind picked up while I was doing the passenger, so I'll have to grind some of that out today.
Sheared all the hub bolts on my front passenger...and somethings went in kapooey in my trans. Clutch is certainly done, but now I'm gettin 0 power to my wheels at all. I think I'm going to take up disc golf...
Changed out the hpop fittings and o-rings on the 7.3 seems to have cured the last of the oil leak.
Cleaning up the 60 I bought a while back for my k5
Yes I know the caliper bracket is on backwards and the spindle isn't up there. Just put it up there for the time being. Still gotta pull the passenger side apart and clean it all up. Went through 3 wire wheels already and 2 cans of paint.
I wasn't planning on doing fenders or a tire carrier but I needed more room in the back of the jeep and it's nice to be able to see when your riding in the greasy stuff.
took my hatred of the radio stations in the triad to a new level.... made me cut my dash all up and install a double din touchscreen
cut out the lower plastic piece that separates the radio from the A/C controls completely out.
used the plastic from the tray that i cut out to fabricate some brackets
screwed the radio to the new brackets
fit the bezel to see how much i am going to need to cut... then i decided it was late and i have had too many beers to use power tools (don't ask what happened last time)
the bezel is going to get cut tomorrow and then i will need to glass the sides to make it look factory... some sanding.... some more sanding.... them some more sanding.... and finally after more sanding it will look semi half assed... then a bit more glass, and just a bit of sanding and some KRYLON... (if you can't duck it, paint it) followed by copious amounts of BEER and telling myself it looks factory... i will be done...
120 gigs of my tunes and some pandora through my iPhone and followed by the occasional DVD i should forget all about the sucky ass radio stations here...
